Augmentation ram pc portable lenovo ideapad 330-15arr amd ryzen 5 ram 4go
Bonjour, j'ai ce pc portable depuis près d'un an et demi : https://www.cdiscount.com/informatique/ ... 09lfr.html
Je souhaiterai ajouter de la Ram, actuellement j'ai 4Go soudé integré a la carte mère et j’hésite a acheter 4 ou 8 go supplémentairement
Voici ce qu'indique CPU-Z:
Socket 1 ID = 0
Number of cores 4 (max 4)
Number of threads 8 (max 8)
Name AMD Ryzen 5 Mobile 2500U
Codename Raven Ridge
Specification AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
Package Socket FP5
CPUID F.1.0
Extended CPUID 17.11
Core Stepping RV-B0
Technology 14 nm
TDP Limit 15.0 Watts
Core Speed 1596.8 MHz
Multiplier x Bus Speed 16.0 x 99.8 MHz
Base frequency (cores) 99.8 MHz
Base frequency (ext.) 99.8 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, AVX2, FMA3, SHA
Microcode Revision 0x8101007
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 64 KBytes, 4-way set associative, 64-byte line size
L2 cache 4 x 512 KBytes, 8-way set associative, 64-byte line size
L3 cache 4 MBytes, 16-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 8000001Fh
Cache descriptor Level 1, D, 32 KB, 2 thread(s)
Cache descriptor Level 1, I, 64 KB, 2 thread(s)
Cache descriptor Level 2, U, 512 KB, 2 thread(s)
Cache descriptor Level 3, U, 4 MB, 8 thread(s)
FID/VID Control yes
# of P-States 3
P-State FID 0xA64 - VID 0x35 (20.00x - 1.219 V)
P-State FID 0xC66 - VID 0x60 (17.00x - 0.950 V)
P-State FID 0xC60 - VID 0x66 (16.00x - 0.912 V)
Chipset
Northbridge AMD Ryzen SOC rev. 00
Southbridge AMD Carrizo FCH rev. 51
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR4
Memory Size 4 GBytes
Channels Single
Memory Frequency 1197.6 MHz (1:12)
CAS# latency (CL) 17.0
RAS# to CAS# delay (tRCD) 17
RAS# Precharge (tRP) 17
Cycle Time (tRAS) 39
Bank Cycle Time (tRC) 56
Command Rate (CR) 1T
Uncore Frequency 598.8 MHz
Qu'en pensez vous, voila ce que me propose crucial: https://www.crucial.com/scanview/1EC25B ... 6C3#memory
Merci de vos avis concernant si je dois et je peux prendre 4 ou 8 Go et quelles caractéristiques de mémoires dois je prendre?
Socket 1 ID = 0
Package Socket FP5
CPUID F.1.0
Core Stepping RV-B0
Technology 14 nm
FID/VID Control yes
# of P-States 3
Chipset
Memory Type DDR4
Channels Single
